![]() | Home > General > Towbar electrics - how much?! |
DavidHirst Member Since: 07 Sep 2013 Location: york Posts: 93 ![]() ![]() ![]() |
Buy the genuine L/R kit off fleabay and fit it yourself |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
From memory Ripon Landrover charged me 100-150 pounds supplied and fitted.
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
I've done mine . it takes a couple of hours and I'm no amateur mechanic in fact the opposite |
The "software" mod does a lot more than parking sensors. Turns off rear fog light when towing, uses a different map on the gearbox and turns off rear parking sensors on earlier cars. Having suffered the results of a botched install from dealer on my first V6, it is advisable to get the function switched on in canbus to avoid gearbox going into freefall. Those who have got away with it are lucky rather than wise. |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 ![]() ![]() ![]() |
I just bought these (£109). Fitted in about 2 hours (half in the dark with a torch). Wasn't the easiest thing to feed the wiring down behind the bumper of the HST, but alas, finally all went home and works a treat.
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
Ebay http://www.ebay.co.uk/itm/Towbar-Electrics...41687087e0
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I did a "How To" here
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
I was told that it is necessary to remove the bumper but from the referenced "how to" it seems that it might not be necessary. Could you please confirm this? |
Hi mine has the hst bumper and did not remove it , 2007 SUPERCHARGED HST |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4454 ![]() ![]() ![]() |
Some of the newer models require the bumper to be removed to fit |
MY2010? Where would that fit with this? |
I didn't for this installation. Bumper is very easy to remove but there was no need. |
