![]() | Home > Off Topic > Do you switch your air con off to save Fuel? |
JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435 ![]() ![]() ![]() |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1878 ![]() ![]() |
+1
JimR Member Since: 20 Dec 2013 Location: Lichfield Posts: 66 ![]() ![]() ![]() |
Mine is on Auto all the time. It also de-humidifies the air and helps stop misty windows in the winter.
SPX Member Since: 27 Dec 2012 Location: South Yorkshire Posts: 587 ![]() ![]() ![]() |
I always have the air-con on through summer AND winter because of instances like that in the OP.
I seem to remember that on a 38A the default setting was ON. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
I run mine constantly, just adjust the temperature. If you don't run it, it will get smelly when you do, like a stale urine smell. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
I leave mine off, but turn it on regularly to lubricate the seals. If left on for long periods I find it dries my mouth & nose up a bit as it removes moisture from your body too.
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
on all the time .....
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
So you just leave the econ light off then it kicks in the AC as and when required? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
I've always had my air con / climate control running all the time in all of the cars that have had it fitted. I heard long ago about the issue with seals etc. drying out. But more importantly is that I want the air inside the vehicle to be at the correct temperature and humidity - that's what the system does after all!
Half a mile? Make the little darlings walk! ![]() 2008 TDV8 - it was a labour of love and is much missed |
