Home > General > passenger door rattle/ speaker vibration
TMUNRO87
On songs with deep bass my passenger door vibrates, ive stripped off the door card but still cannot find the culprit, anyone experienced this? I dont think its the door card itself Black Range Rover Sport Supercharged 2005 with exterior overfinch bodykit
Mods:
Gvif/freeview tv/ reverse camera/led headlight and tail light conversion
Post #426174 Tue Jun 03 2014 5:36pm
simple1
Lots of things in a door that can vibrate and wear causing movement. If the membrane is complete, it may be wear, if the door has been opened, check security of everything including loom, it could also be the speaker itself blown due to water ingress or too much boom boom. Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #426343 Thu Jun 05 2014 6:42am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
With the door card installed pick a song to get the vibrations, then firmly push systematically over the whole door card to see if applying pressure in a specific location reduces/ stops the vibration. If it does you will know the approximate area from where the rattle/ vibration is coming from.
If this doesn't work remove the door card as Simple1 said and check all connections/ fixings etc. contained within the door.
I had a rattle and squeak from the rear and it was found to be worn or broken fixings of the lower boot trim/ card. I got the garage to replace all fixings and add sticky backed automotive felt tape where the trim meets the metal boot lid. Solved the problem no squeaks or rattles.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #426347 Thu Jun 05 2014 8:40am
TMUNRO87
Thanks for tips, rattle has disappeared but im sure itll be back at some point so i can try finding culprit. Black Range Rover Sport Supercharged 2005 with exterior overfinch bodykit
Mods:
Post #426576 Sun Jun 08 2014 6:38pm
