![]() | Home > Wheels & Tyres > Damaged tyre sidewall |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 ![]() ![]() |
I would say you need a new one also i won't pass an mot like that eather |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
I had a blow out on a rear tyre that was nearly new and completely undamaged.... only doing 70´ish mph in my MY12 RRS
Tread looks a tad thin as well, looks like 4 new boots needed. Try Dan at Duckworth, he may have some new take offs. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
+1.. didn´t even notice tread.... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 ![]() ![]() |
depends how deep the cut is. Best to go to your local friendly tyre shop and seek their advice. |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 ![]() ![]() |
New tyre now ordered! The tread is not too bad on the centre of the tyre but the shoulders seem to be quite worn; they are Continentals if anyone is interested! |
Tread looked OK but when compared to actual wear mark, it probably only had another 1000 miles left on it! Other side just as bad - another new tyre on order! |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
A wise move would be to increase your tyre order to FOUR and get the tracking checked. |
Front tyres only changed in March but good advice about the tracking! |
stealth Member Since: 09 Jul 2014 Location: Hampshire Posts: 30 ![]() ![]() ![]() |
Def new tyre |
