![]() | Home > General (L494) > SC 3.0 V6 |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Yes, not available in the UK where we have the choice of an under-powered V6 diesel, an over-priced V8 diesel with only marginal improvement in performance numbers (though probably a better drive) and a thirsty hard to obtain super-charged V8 petrol.
Nigel Tracey Member Since: 25 May 2014 Location: Lausanne Posts: 44 ![]() ![]() |
Thanks for that comprehensive reply, clears it up at least.
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
Underpowered? The SDV6 has more than enough power for me! Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
That's only because you're not manly enough for a V8 Chris. |
Underpowered? Well, the SDV6 has about 290 bhp; the lower cost (though probably the same by the time you've spec'd it up), Porsche Cayenne Diesel S has 380 bhp, so if the RRS is to compete with its most obvious rival, it's short on power. Of course, not everyone buys a Range Rover Sport for the Sport... Mark
I don't I'd bother with the V8, if I wanted power I would go straight for the Supercharged. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
Good point! |
Must admit that after I tracked down the stats on this engine I was surprised that it's not that much quicker than the SDV6 although I expect it's more responsive and has a nicer sound, wonder if the extra fuel is worth it ?
What surprises me is that the SDV8 is as expensive as it is and, like you, the power is as low as it is, though it has the highest torque of all so good for towing your yacht...
OK so had a long test drive in the 3.0 V6 SC today, country roads, estates and highway. It's quite a different animal vs the SDV6 and I'm not sure how but it seemed even smoother, made my D4 seem like a tractor |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
The SDV6 is a fantastic engine, which offers power, mid range pick up and economy.
The SDV6 is the engine you have so I suspect you'd say that.
Compared to a Defender, maybe... Mark SVR in Estoril Blue ![]() |
