Home > Faults & Fixes > Access mode
Maidenmania
Access mode
Hi
Wondering if anyone can help. When I put the sport into access mode it lowers then raises to it highest setting. Anyone any idea how to fix this? By the way it's a 2008 HST 2008 Factory HST- Sold
Arrived 2016 HSE carpathian grey
Post #425163 Sat May 24 2014 4:17pm
PEACHY
You have a fault Big Cry might just be a height sensor - Sport thinks its hit he bump stops ( lowest point ) & therefore pushes it into extended mode to protect it - ideally you need a fault reader to identify the problem. Thumbs Up 16MY Estoril Blue SVR.............
Post #425171 Sat May 24 2014 5:56pm
Maidenmania
Got a mate with one of those cheers 2008 Factory HST- Sold
Post #425180 Sat May 24 2014 7:27pm
factoryfil
United Kingdom 2006 Range Rover Sport TDV6 S Java Black
It's probably the intake filter on the air compressor. it gets partially blocked with air drying beads and
dust etc. over time, when the access mode is selected the air in the system is exhausted too slowly and the lowering process is slower than the preset time, so then the system thinks there is an obstruction under the vehicle, then decides to raise the vehicle off the obstruction......
Post #425310 Mon May 26 2014 5:46pm
