Home > In Car Electronics > Gvif, Reverse Camera & TV Tuner Install |
TMUNRO87 Member Since: 05 May 2014 Location: Essex Posts: 32 |
Heres the pics from the reverse camera install, found it quite difficult and struggled with routing wiring around boot, but its in and functioning as it should. Broke my phone from when i did the gvif install so not as many pics of that but ill load what i have in the next post.
Sat May 17 2014 11:58am |
Sat May 17 2014 12:07pm |
JMJ Member Since: 18 May 2014 Location: Wales Posts: 5 |
Hello, please could you offer some advice regarding getting a rear view camera working in my RRS. I have bought a GVIF interface unit, LR gvif lead and reverse light camera. Am I right in thinking the grey [rear] on interface needs to be connected to reverse light live feed along with the live to camera?
Sun May 18 2014 3:58pm |
Yes the grey wire on the gvif has to be connected to your reverse light, i took mine from the rear left cluster. Its the upper centre cable out of the six on the mconnector you need, green and red i think the cable was. I personally didnt connect my camera power feed into The reverse light as i got mine set up so i can switch to the camera without selecting reverse. Instead my camera is wired into the back of the cigerette lighter in the boot. My yellow av video lead has a splitter on it meaning it goes into the rear camera input and my av3. Black Range Rover Sport Supercharged 2005 with exterior overfinch bodykit
Sun May 18 2014 5:39pm |
Thankyou for the help, I 'will be having a go at getting it all in there this week. Can anyone comfirm the switch positions? |
Tue May 20 2014 8:34pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
Have a look in my gallery 16MY Estoril Blue SVR.............
Tue May 20 2014 9:03pm |
BRO-T Member Since: 10 Mar 2014 Location: Solihull Posts: 34 |
Hi, can you tell me where you brought the camera and GVIF interface. I.m buying a RRS 2007 later this week and first thing I want to do is install a reversing camera.
Sun May 25 2014 9:57am |
I bought through Amazon but it actually comes from Asia. I then had to buy the correct Land Rover cable as it came with the Lexus one. |
Sun May 25 2014 3:19pm |
I've tried setting my camera up this morning, but its not working. I have wired in and set switches as above.
Mon May 26 2014 11:35am |
Hey buddy test the camera by plugging it into one of your av ports. Also check your camera is getting a 12v feed. The unit is switching so hopefully its ok that end. Black Range Rover Sport Supercharged 2005 with exterior overfinch bodykit
Mon May 26 2014 8:47pm |
If your camera is fed off your reverse light make sure you put car in reverse when testing on another av port too. Black Range Rover Sport Supercharged 2005 with exterior overfinch bodykit
Mon May 26 2014 8:48pm |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
The GVIF units and cameras are available from Hids4u near Southampton. Google them MY16 AUTOBIOGRAPHY Indus silver with some toys 2012 3.0 SDV6 Luxury gone, but a great motor |
Mon May 26 2014 9:29pm |
Hi TMUNRO87
Tue May 27 2014 7:04am |
When I did mine i took the 12v for the camera from the 12v cigarette socket in the boot and the feed for the reverse from the wires behind the reverse light cluster in the rear MY16 AUTOBIOGRAPHY Indus silver with some toys
Tue May 27 2014 8:12am |
