Home > Off Topic > After sales brake pads and discs |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
did you copper slip the back of the pads prior to fitting, this helps a lot |
Thu May 15 2014 8:52am |
Fozzer Member Since: 15 Aug 2013 Location: Merseyside Posts: 33 |
Hi Monty 19 I have removed the brake calipers and had them on a wire wheel to remove any build up of rust or corrosion I have fitted new brake shims and lot of copper grease. but still can not stop the brakes from squealing I will go and get a different make of pads and fit them and see how they go But not from the suppler I got the first ones from |
Thu May 15 2014 9:22am |
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 |
Mintex pads usually quite good, doesn't mention the brand of Disc they supply Sophie Alltoft
Thu May 15 2014 10:03am |
Just standard britparts are the make of disc. Pads SPF 500010' discs. SDB000604 |
Thu May 15 2014 10:19am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
IME, Mintex pads are |
Thu May 15 2014 3:59pm |
