Home > Orders (L494) > EARLY STAGE OF POSSIBLE ORDER |
alanad Member Since: 01 Dec 2010 Location: Livingston Posts: 133 |
In answer to your questions:
Mon May 12 2014 6:48pm |
Wing-Co Member Since: 10 May 2014 Location: MUNSTERGELEEN Posts: 8 |
Cheers Alan, I was on the route to a new BMW and probably the new X6 to be different from my X5 when I called in my local dealer and parked next to a RRS 2014. It had a presence that made my 2011 X5 look overwhelmed and the test drive was really nice, in particular the ride and the upmarket feel of the interior. The connected drive and wheel control in the X5 allows you to use many functions whilst on the move; when i've used the companies Mondeo with the touch screen I've not had confidence and it is a slight worry about the RRS, but I think one I am prepared to accept. The X6 4.OD would be much faster and firmer, but I feel the RRS offers a drive that suits my driving more.However, driving in Germany regularly speed is infectious and it is surprising how when your foot is flat to the floor in an X5 you wish it had more as Audis and Porsches come past you! |
Mon May 12 2014 7:18pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
My 2014 has air con front and rear. The max fan speed is pretty weedy imo. Apart from a few days in France when the temps were 22-24 deg in the afternoon, there's not really been an opportunity to see how effective the air con is on a hot day...But there's no real blast of cold air on max settings - in contrast to the D4.
Mon May 12 2014 10:03pm |
Many thanks PB, I'll have to have a fiddle withe the ac on Fri when I go for another test drive. On my X5 it is very effective in all modes and no extra ac is required in the back to supplement the manual vents in the rear console. |
Tue May 13 2014 3:12am |
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 |
You can adjust the auto fan speed in the AirCon setup screens to always blow less, we have and it works well for 95% of the time. If you need more flow just turn it up. |
Tue May 13 2014 11:57am |
Thanks Disco...I didn't realise there was an air con set up screen! Where is it? I presume it's within the climate control menu, in which you can alter the fan speed front and rear, manually, but chucking it back on auto the fan speed defaults to too high a setting.
Wed May 14 2014 10:24pm |
Yes if you manually adjust the fan speed it will reset if you push the Auto button.
Thu May 15 2014 10:57am |
Yes, found it in the settings menu, so I've taken it down to minimum! Thanks! |
Thu May 15 2014 11:34am |
Hi Folks, back from looking again and test drive. Specified with the dealer as below. Now just a bit of work on price for my X5 from them and then to decide whether to stick with my X5, change for RRS or wait for new X6.
Fri May 16 2014 6:49pm |
