Home > Maintenance & Modifications > installed Drl led running lights 55 rrs sc
TMUNRO87
so had my headlights converted to have Drl, at the moment they are activated by turning on side lights although im told they can run in the off position by reprogramming to Canadian/scan option. Does anyone know if there is a way to have drls running at the front without brake lights on too?
Post #423909 Sun May 11 2014 9:28am
scarey
i have a drl switch box which activates the drls when you switch on the ignition..cost is around £8-10 of ebay..
Post #423911 Sun May 11 2014 9:43am
TMUNRO87
Hey pal could you explain this to me? Is it different from turning your lights onto parking and do the brake lights come on as well, also could I be cheeky and ask what to search or for a link? Thank you
Post #423971 Sun May 11 2014 6:18pm
scarey
i have one similar to this one, but there are others available,
http://www.ebay.co.uk/itm/LED-Daytime-Runn...5409301217
the unit is bolted on in the engine compartment, two pair of wires go to the leds ,the others to the battery and headlight feed.
so when you switch on the engine the drls come on automatically, if you connect the headlight feed, then when the headlights are switched on the drls go off..
Post #424010 Mon May 12 2014 7:56am
TMUNRO87
This is sounding like a good option. Where did you take your ignition feed from and does this unit backfeed turning your tail lights on too or just yoyr drls? My leds are in the leadlight so by putting power into harness from this unit im wondering if taillights will come on too. Black Range Rover Sport Supercharged 2005 with exterior overfinch bodykit
Mods:
Gvif/freeview tv/ reverse camera/led headlight and tail light conversion
Post #424538 Sat May 17 2014 12:58am
