Home > Maintenance & Modifications > Lowering links or eas tool?
medders
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
What's best to lower my RRS ????
Post #423773 Fri May 09 2014 2:43pm
PEACHY
Sad I thought you got this sorted ?? Laughing
Thumbs Up 16MY Estoril Blue SVR.............
Post #423780 Fri May 09 2014 4:41pm
medders
Not yet , needed wheels refurbed first, but not sure what option best :-/
Post #423781 Fri May 09 2014 4:42pm
flydive
It depends.
If you want it "permanently" lowered, then links I guess.
If you want max flexibility, then EAS tool
If you want a bit less flexibility with more convenience and ease of use then LLAMS '08 RRS TDV8
Post #423837 Sat May 10 2014 9:49am
aljo
IID bt tool Thumbs Up
Post #423852 Sat May 10 2014 2:41pm
medders
Yes want it permanent so probably go with the links Smile
Post #423907 Sun May 11 2014 9:01am
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I'd expect the EAS tool to put the suspension in access mode, this is surely not designed to ride low and would result in issues down the road? Even with links I'd still expect issues. Though there are issues already without messing with the ride height. I'd go EAS tool first and not go as low as the access height, but create an even lower parking pimp height in it so when you park up it looks the dogs.
But for normal driving, I'd set it somewhere in between. Links will not let you do that.
Post #424052 Mon May 12 2014 3:47pm
medders
Id only want 10-15mm anyway so probably going for the links option
Post #424060 Mon May 12 2014 5:03pm
Stryke
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Eas or IID - a good investment!
Post #424572 Sat May 17 2014 6:03pm
