Home > General > Front Suspension Slow to Raise?
simonj007
England 2007 Range Rover Sport Supercharged Zermatt Silver
Just the last couple of days the front suspension is slow to rise - possible faults?
On the center screen both front wheel 'lines' on the 4 X 4 display flash red for a time while it lifts slowly.
Any thoughts appreciated.
Regards,
Simon
Post #423760 Fri May 09 2014 11:13am
daveyc
United Kingdom 2006 Range Rover Sport Supercharged Siberian Silver
Sounds like the compressor if you can get a code reader possible with isolate your fault , very common to have faults on, got a problem with mine at the moment but code showing control unit fault , I can inbox you the workshop manual if u want .. 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
2007 2.7 v6 Chrysler Sebring convert sport
2006 SRT8 6.1 ltr petrol 300 Chrysler gone
2005 X5 3.0d sport gone
2001 BMW 330 ci ltd edition mtec gone
Post #423763 Fri May 09 2014 11:47am
Could be the front valve block. Could be the reservoir valve block (splits air to the front and rear and the reservoir). Both parts are less than £100 and possible to do DIY apparently. 2012 SDV6 - it's missing a couple of cylinders
Post #423783 Fri May 09 2014 4:13pm
