Home > Wheels & Tyres > Check your nuts |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
This is discussed regularly on Disco
Wed May 07 2014 7:56am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
For clarity, it's the standard non-locking nuts that are failing on my RRS.
Wed May 07 2014 8:04am |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Had the same problem with mine at the weekend. The chrome covers are now so distorted they don't fit a standard socket anymore. I replaced all the lockers last year and they're fine but looks like a new set of standard nuts would be a good idea too. Group buy anyone ?? FF 4.4 V8 Soooo looking forward to this bad boy
Wed May 07 2014 11:48am |
Did you put lockers back on or do you just run non-lockers on all nuts? 2012 SDV6 - it's missing a couple of cylinders
Wed May 07 2014 1:18pm |
I put the lockers back on. They are only about 6 months old - bought from Duckworths, but I can see the merit of not using them given their propensity to split. FF 4.4 V8 Soooo looking forward to this bad boy
Wed May 07 2014 1:53pm |
How do you stand with insurer if removed - I would be worried they class this as modification Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed May 07 2014 1:58pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
I have a set of wheel nuts going, well minis 4 as i ve kept the locking nuts. £25 p&p. |
Wed May 07 2014 2:39pm |
Sorry. minus. |
Wed May 07 2014 2:40pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
With the fact that almost everything on an RRS seems to be fair game for your petty thief at the moment, I wouldn't risk not putting locking nuts back on. ON THE WAY: BMW F21 M140i
Wed May 07 2014 2:57pm |
Do we believe it could be down to the use of the air /electric powered impact guns workshops seem to use for everything ! |
Wed May 07 2014 3:04pm |
It could be that. Looking at the nuts, the shiny outer coat is just pressed on with the material being pressed around small corners near to the shoulder of the nut to secure it. I guess a combination of water getting in between the nut and coating causing some corrosion plus the use of aggressive power tools could cause the issue.
Wed May 07 2014 3:22pm |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
Do you think the off road work or water crossings have had any impact on the corrosion ? |
Wed May 07 2014 3:45pm |
I suppose it might do but the rears get soaked whenever you drive in the wet anyway from the spray coming from the front tyres. I'd have thought salt from winter roads would be a bigger issue than running them through deep, salt-free water. It's a well known issue on the D3/4 site, it seems, and I'm sure many who are affected don't use their vehicles off road.
Wed May 07 2014 5:12pm |
I would put money on power tools used by dealer - they also scratch alloys around nuts Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed May 07 2014 5:26pm |
