Home > Technical > Black smoke
approved
United Kingdom 2006 Range Rover Sport TDV6 HSE Siberian Silver
Black smoke
When I accelerate heavy I get a cloud of black smoke behind me when you drop the acceleration down it clears any ideas turbo or seal?
Post #421951 Tue Apr 22 2014 4:09pm
It's a diesel, they all do that to a lesser or greater degree. Has it had a remap done? Excessive fuelling will cause black smoke. 2012 SDV6 - it's missing a couple of cylinders
Post #421959 Tue Apr 22 2014 4:58pm
Disco_Mikey
Probably a split turbo hose. Very common on TDV6 Thumbs Up
Post #421972 Tue Apr 22 2014 6:37pm
chi
Had this very recently on my 55 plate tdv6. Black smoke on acceleration.
EGR valves blanked off solved the problem completely. Could be same problem
I beleive this can only be done up to 2007 models?
Post #422073 Wed Apr 23 2014 6:00pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Had the same AFTER the both EGR valves were replaced.
Turbo hose was split, probably by mishandling LR dealer Barcelona. Evil or Very Mad
After quick replacement, the car was fine. SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #422076 Wed Apr 23 2014 6:27pm
rich_z3
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I had this it was a turbo hose
Post #422077 Wed Apr 23 2014 6:29pm
Sag
I had this - Tried blanking EGR valves & replacing Turbo hoses. Neither worked.
More investigation showed damage to the Intercooler (looked like it was hit with a rock). Had this replaced and rectified the problem. LCFC. Receiver of threatening letters from Overfinch.
Post #422085 Wed Apr 23 2014 7:36pm
Split hoses / damaged intercoolers all lead to the same thing - over fuelling because the system expects a certain amount of air to arrive at the engine and some of it disappears through the hole before it gets there Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #422103 Wed Apr 23 2014 11:46pm
Chin
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
Could someone help me locate the turbo house to check this out please?
Post #422250 Fri Apr 25 2014 10:08am
shakeapaw
lift up your bonnet and look down at the engine, there will be two rubber pies/hoses, both identical, both running from the intercooler, one to each turbo 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #423275 Mon May 05 2014 1:06pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
would you hear it Mike if the hose was split and would it put engine system failure light on as im having a similar problem with the sport i put an engine in silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #423286 Mon May 05 2014 3:36pm
idrabble
Australia
shakeapaw wrote:
two rubber pies
Mmmmm! Rubber pies. Would be the food that keeps you chewing forever. Laughing
Post #423326 Mon May 05 2014 11:31pm
shakeapaw
Rolling with laughter fat fingers, or was I just hungry Razz 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #423472 Tue May 06 2014 11:02pm
