Home > General > i think my gearbox has :censored: its self
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
how many owners have had there gear boxes go knackered Big Cry
Post #422626 Mon Apr 28 2014 8:05pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
You would wonder how they do - its automatic, so not driver caused surely. It scares me the though of mine breaking, how does it happen and are there steps to prevent it?
I watched a guy who works on LR gears and he mentions changing transmission fluid before 100k, mines 100k and I'd wonder if I should or not.
Post #422630 Mon Apr 28 2014 8:21pm
cossiedave
if its not been done i would change oil and filter with them miles mate ,its an expensive job if it goes wrong
Post #422637 Mon Apr 28 2014 8:42pm
designboy
Good man, I'll get that checked and done. Its had full LR history and a few bits over the years done - I'm keen to keep it in good order and follow on with LR even though they can be questionable in service.
Post #422642 Mon Apr 28 2014 9:20pm
Disco_Mikey
The oil starts degrading at 60k-ish miles
Post #422645 Mon Apr 28 2014 9:27pm
designboy
Yea that is what I'd seen in the video, so is this part of the servicing at LR?
Also I kept a copy of this fine info from Paddi but it says every 10 years or 150k:
Every 2 years or 30,000 miles: Replace fuel filter.
Every 3 years or 45,000 miles: Replace brake fluid.
Every 3 years or 45,000 miles: Replace the air cleaner element.
Every 5 years or 75,000 miles: Replace transfer case oil.
Every 6 years or 90,000 miles: Replace all flexible brake hoses.
Every 7 years or 105,000 miles: Replace the ancillary drive belt.
Every 7 years or 105,000 miles: Replace camshaft timing belt and high pressure fuel pump driving belt. (n.b. TDV6 only; the TDV8 camshafts are chain driven).
Every 10 years or 150,000 miles: Replace the engine coolant.
Every 10 years or 150,000 miles: Renew automatic transmission fluid.
Every 10 years or 150,000 miles: Renew front and rear differential oil. (5 years if rear diff is ‘active’ type).
Post #422652 Mon Apr 28 2014 10:09pm
cossiedave
My rangy has just gone in to get my gearbox fixed so let's hope it's like new when I get it back
Post #422849 Wed Apr 30 2014 12:23pm
Disco_Mikey
ZF, who manufacture the gearbox, state that the oil should be changed at 75k miles.
Land Rover, in their infinite wisdom, say 150k/10 years. For 99.9% of D3/D4/FFRR/RRS, they will not cover anywhere near this mileage within the first 3 years of it's life, so when the gearbox gives issues, it is way outside of the warranty period.
And not LR's problem, leaving the customer to pick up the bill for a gearbox repair Rolling Eyes
Post #422895 Wed Apr 30 2014 7:53pm
shakeapaw
well after months of messing about, my gearbox is going in for repair, it all started 6 months ago when on the motorway, if you used kickedown, the car would display limited gears available and go into limp mode. However if you never used 5/6th gear, then the motor was fine, however ive now had enough so its going in to be fixed, Ive been told around £1600 will get the box reconditioned.
I had my oil changed, though that was around 100,000 miles, hopeing that would cure it, infact it made it worse as it kepted dropping gears in 4th as well 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #423260 Mon May 05 2014 12:18pm
cossiedave
I still haven't got mine back yet mate and the 1600 sounds very cheap. Is it a well known place
Post #423261 Mon May 05 2014 12:28pm
shakeapaw
Thats for the gearbox repair, as its a known fault with these zf boxes, the overall bill will be a lot more when labour and vat are added 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #423270 Mon May 05 2014 1:52pm
cossiedave
mine has gone to a place in preston called preson automatic transmissions
Post #423293 Mon May 05 2014 7:25pm
shakeapaw
Ive no idea where mine will end up, the local Indie garage uses him, we will have to compare notes later Very Happy 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #423469 Tue May 06 2014 11:57pm
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
How did it go Shakeapaw?
Did you get it sorted and at what price?
Think mine needs replacing/reconditioning soon. Big Cry
Post #437860 Thu Sep 25 2014 10:53pm
shakeapaw
no idea why I never got a notification for this post, I guess yours is fixed now?
£2000 all in, everything now works again, but it just isnt the same, it doesnt feel the same!!!!
It drives better and the mpg has gone up from 19 mpg to 24 round town and up from 22 mpg to 28 on the motorway, however sometimes it sets off too quickly, other times its sluggish? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #482299 Sun Dec 13 2015 10:37am
