![]() | Home > Technical > Whirring noise under my feet |
We used to get something very similar on D2's fitted with ACE the pipes run along the chassis rail under the drivers side. Used to get a high pitched whine, it was by caused the pipes resonating with the hydraulic pressure.
mrbet Member Since: 08 Apr 2014 Location: manchester Posts: 4 ![]() ![]() |
Thank you for the reply.
Try repositioning the pipes, make sure there not fouling anything. Get some one to flex the pipes while your in it to see if the noise changes pitch 2008 G4 RRSport TDV8 current
You were spot on. It took them a week to realise and replicate the fault, even though I'd told them what you'd said.
