Home > General > RRS tdV8 HST |
You're confusing the two issues: Decent long runs using top quality fuel and an additive, if you think the engine has been used for only short runs and is likely to have heavy sooty deposits in the combustion areas (piston crown, valves and head space), should reduce the deposits. Oil sludge builds up in the oilways inside the engine when the oil isn't changed frequently enough or the wrong oil is used and especially if the car is used for short runs only. The only way to get rid of the sludge is to change the oil and if it is very black and contaminated run the car for a week or so and then change the oil again. Change the oil at half the recommended intervals i.e. about 7k miles not 15k. Don't use oil flush - most engineers agree it does more harm than good. Only use OE filters and take care when fitting that the spigot is properly engaged before bolting down. Use the correct spec oil and make sure the engine is properly warmed up before draining out the old oil. Oh yes - and be aware there are two sump plugs to remove when draining. They are not re-usable so you'll need to buy two for each change of oil. Having said all that I had better practice what I preach - just about to change my engine oil this morning! 2008 MY Java Black TDV8 HSE |
Sun May 04 2014 10:12am |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
I must google how to do an oil change then. Guessing its straight forward enough.
Mon May 05 2014 9:23pm |
