![]() | Home > Australia & New Zealand > Cape York Trip |
Unscathed is quite common if you are sensible - there is no need to do every hard section as there are 'chicken tracks' around most of the hard bits. The people who come unstuck are those gungho types who must try everything. It is not worth damaging your car when you are 600km from no where.
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
was it a 3 litre diesel nissan Garry, hearing some scary stories about GU2 models, in particular 00 to 03 models,
Was a Navara. Definitely do not go in in non CRD 3 litre patrol - they are grenades and Nissan never fixed them - I hope that is 4.2 diesel Patrol you have there - tough as old boots.
Nissan fell through and after another weekend of fruitless searching i took the plunge today and ordered
comprehensive cost as well BC |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
About £3.5-4k. Sadly, such kit is almost impossible to source for the RRS here in the UK.
For your trip the only things I would get from your list is the EAS Kit, a RAI converted to a snorkel and the second battery system and you could probably get away without the RAI. You need to also be looking at a UHF, personal locator beacon, hire a satphone, Maxtrax, air compressor, tyre plug kit, rods or LLAMS, recovery kit and a jack - the LR jack is not suitable for offroad use. Sounds like a great trip. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
GC, in terms of the snorkel i am just not taking any chances of hitting any potholes on
I don't disagree with your list of goodies for the long term but I took it that the mods were just for this trip.
Garry, Opposite lock at Brookvale are fitting it, they have already done one for a company who do mine
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Zilchy.... |
Well you are certainly thinking alone the right lines.
MartyRRS Member Since: 04 Dec 2013 Location: Adelaide Hills South Australia Posts: 25 ![]() ![]() ![]() |
hey Garry, can you replace the shocks seperate to the airbags? Regards, Marty
I haven't had to change mine but as far as I am aware they are two separate items and shockies can be replaced independent of the airbag. I suspect the whole lot comes out as a strut and the shock then changed. Apparently not such a big job.
