Home > General > Pants, lost my lock nut! Only a week into owning the thing! |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
I just ran a search here. Turns out I'm not the first. Good advice here too to get it sorted for under a tenner ; ) |
Sat Apr 26 2014 8:44pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8968 |
You could go to your local LR dealer and ask them to remove the old locking nuts and then put a fresh set in. LR dealers have a full set of locking nut keys. 2012 SDV6 - it's missing a couple of cylinders
Sun Apr 27 2014 7:30am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Even better advice is to have lockers removed, and replaced with normal wheel nuts |
Sun Apr 27 2014 7:44am |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 |
Why do you say that Mikey? |
Sun Apr 27 2014 11:07am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1939 |
Where was it, in the pocket of your pants? I don't understand the connection between your pants and your lost nut? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sun Apr 27 2014 3:25pm |
He was using the word "pants" as an alternative to one of the usual expletives...but I reckon you knew that 2012 SDV6 - it's missing a couple of cylinders
Sun Apr 27 2014 5:58pm |
Because they have a nasty habit of splitting, and falling apart. All of the strength is in the outer part of the nut, which splits and falls apart. When that happens, the softer steel is not strong enough to undo the wheel nut, and so, leaves you stranded at the side of the road... |
Sun Apr 27 2014 7:12pm |
Very interesting, thanks for the reply Mike. |
Sun Apr 27 2014 7:19pm |
Thanks much RRS Tdv8, I didn't because it's not an expression we use here. Pants or Strides or occasionally trousers are what you call trousers. We would just say F . Thanks, it's a new one I will use like minger (a short version of that means something else too) Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sun Apr 27 2014 9:32pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
my local garage tells me that every time i go there to change tyres/wheels/fix puncture. there must surely be a locking nut stronger than the lr oem ones, anyone ? pulling up an image search gives me this: https://www.google.co.uk/search?q=locking+...p;tbm=isch Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Sun Apr 27 2014 9:42pm |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
Having read plenty of threads where locking nuts have caused problems, and only one report of wheels stolen from the hubs (that had locking nuts), I can't really see the value in such, especially given the easy availability of tools to defeat them. Rather than buy a replacement key, I'd suggest doubling the budget and buy four regular nuts. |
Mon Apr 28 2014 9:52am |
Alloy wheels used to be relatively rare things and so were prone to being stolen. Now that almost every car produced has alloys they are probably not worth the time and effort to steal them. Especially when one considers how easy it appears to be to steal the vehicle itself with the wheels attached!
Mon Apr 28 2014 11:25am |
As above |
Mon Apr 28 2014 2:16pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Agree 100% with DM. Having suffered the split locker and the local tyre monkeys not putting it on and twisting the groves, and the cost of getting it sorted as PROTYRE refused to accept responsibility, I had locks removed and standard nuts fitted as didn't want to be stuck on side of motorway at night with same problem 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Apr 29 2014 8:38pm |
