Home > Technical > Wet Passenger floor
ICMarshall
Wet Passenger floor
Today I removed the floor mats to hover out the footwells and noticed that the passenger side front carpet was soaked through, the rear was slightly damp on this side as well. Drivers side fine.
The car is a late 2007 3.6TDV8 HSE with no sunroof.
That last bit is important because my search online for solutions just seems to mention sunroof drain tubes.
Anyway door seals look fine, at least no sign of damp from the inside.
Anyone any ideas?
Post #422383 Sat Apr 26 2014 2:24pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Air conditioner drain blocked perhaps?
Regards
Barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #422442 Sat Apr 26 2014 11:49pm
garrycol
Australia
Yes check the a.c drains but I recently had this issue and I found that in heavy rain or when parked down hill the water come in the bottom hole on the A pillar. The outer trim finisher has the clips that hold it on - they go in small round holes but at the bottom the hole is elongated where a positioning moulding goes in and this lets water in.
There was a service bulletin on this - see here you will have to register
http://www.rangerovers.net/forum/attachmen...01-007.pdf
Also see here for my thread on this issue on AULRO http://www.aulro.com/afvb/d3-d4-rrs/194174-water-leak-rrs.html 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #422444 Sun Apr 27 2014 4:31am
ICMarshall
It was the hole at the bottom of the A-Pillar that was letting the water in. Now fixed and dry, details on Technical Bulletin LS501-006.
http://www.rrsport.co.uk/gallery/albums/us...illar2.pdf[/url]
Post #423533 Wed May 07 2014 3:18pm
Barryp
Hi Guys,
What surprised me was that ICMarshall's car is a 2007 but the service bulletin is dated August 2005.
So 2 years after identifying a problem LR had not fixed it on the production line.
A bit slack from my point of view.
I wonder if it was fixed by the time they produced my 2011 RRS?
Regards
Post #423585 Wed May 07 2014 8:11pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Aargh.
This has happened to me today. Front passenger footwell is sodden. And the back passenger side is also wet. When i opened front passenger side door water actually poured out. Its been raining hard for 8 hours today.
Sunroof seems fine and drivers side footwell is dry.
So must be the exterior a pillars.
How do i remove these?
And is it enough to use some sealant at the bottom area or better off taking it to a LR dealer here in Finland and see what they say?
2006 model. So surprising this wasn't fixed years ago?? 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #498827 Thu Jun 16 2016 6:07pm
Johnski
Pakolainen, if you haven't already done so, please check your sunroof and drainage channels and tubes, as this is the most common fault for getting the wet floor-wells. This may not be the cause but it is the first check to do IMO. Once ruled out, then check the window seal and co ear as mentioned above.
Let us know how you get on, this fault should have been picked up at LR a Service Centres, as they do on official print outs state that they have checked for all updates having been done, and any new ones still to fullfill, this doesn't include updating of Maps for the navigation. Which 2016 can now be purchased on line, and uploaded by yourself by the slow dongle method of updating.
Pre 2009 LR and RR models can be obtained here: http://www.satnavdvd.co.uk/2015-landrover-...-196-p.asp
Latest Official LR HD type, (2010-2013) (2013-2015) 2016 maps available here £174.00: http://landrover.navigation.com/product/Ca...erEMEA/GBP John
Post #498842 Thu Jun 16 2016 8:28pm
Pakolainen
Cheers Johnski,
should there be any 'give' in the sunroof? - when fully close if i push up from inside the cabin there is a few mm's of movement?
The exterior A pillars seem to be loose - in that they wobble, not massively but there is movement.
Guess i will be checking it all out. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #498848 Fri Jun 17 2016 5:03am
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, it was the slot in the a pillar on mine that was the problem, not the sunroof. I followed the instructions on here and now it is bone dry, when i opened the door it poured out and it took 4-6 weeks to dry out. I put some clear sealant around the replacement clips, plugs when i done the job, don't just fitt them dry or it will not work, just covered the slot with duct tape. Hope this helps, it done mine Thumbs Up Just to add if you open the sunroof and pour water in both the small holes in the front corners, it should run out both sides behind the front wheels. 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #498850 Fri Jun 17 2016 7:53am
Gornal Hills
Hi, forgot to say that the foam block becomes full of dust and dirt preventing the water to run out, it then back fills up to the slot and in. Don't forget to remove the foam block when you do this Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #498851 Fri Jun 17 2016 7:58am
Pakolainen
Have opened the sun roof and the spacing around that was all dry, inserted a straw in the drainage holes and blew - no resistance. and the internal roof shutter for the sunroof is dry.
Pillars next, which requires getting the replacement plugs - so visiting a LR store here and trying to explain, or the Ebay route.
Cheers 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #498852 Fri Jun 17 2016 8:15am
Gornal Hills
Hi, i'm sure you will find it s the slot problem, it is an easy fix Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #498854 Fri Jun 17 2016 8:36am
Graz
Apologies for my ignorance but given this was a service bulletin, are LR providing this A pillar fix for water ingress free of charge?
Post #498916 Sat Jun 18 2016 5:21am
Gornal Hills
Hi, unsure my friend but no doubt someone on here will know and inform you Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #498919 Sat Jun 18 2016 7:35am
Pakolainen
Evening.
Anyone able to say if the exterior Apillarclips can be boughtfrom ebay? I can find A pillarips but then they all say interior only.
Have called the local dealer several times but no response.
Mazda 3 1.6 2010
Post #499762 Tue Jun 28 2016 3:23pm
