![]() | Home > Maintenance & Modifications > Ride height sensors and valve blocks |
armitage_shanks Member Since: 08 Dec 2013 Location: Melbourne Posts: 2 ![]() ![]() ![]() |
Be careful with the electrical connectors to the sensors. The plastic locks tend to break on the loom side of the connectors when you disconnect the sensor.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Thanks, I'll watch out for that. 2012 SDV6 - it's missing a couple of cylinders
Well that was annoying. Got it jacked up, wheels off, and couldn't get the bolts undone that hold the rear height sensors on. Even with a dose of WD40. Absolutely refuse to move. I don't want to force the issue however as it'll be fun changing them if the bolt heads get damaged so I've decided to put the wheels back on and leave it. I might have another look tomorrow to see if the WD40 has found its way along the full length of the thread.
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
Blow lamp |
It's one option although perhaps a little overkill |
Using a blow lamp isnt overkill, just warm it slightly and it will come straight out. |
I've done that on bigger stuff once that I could get to easily but to get it in amongst the suspension looks to be a bit tricky. I don't have a torch just a burner-on-bottle type lamp that I use for the odd bit of plumbing.
Yeah having a blow lamp that you can adjust is important if its in a tricky location.
No, paying for a "simple" fix is not something I like doing either. But there's no point getting older if you don't get a bit wiser with it... |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
I hope the WD40 works for you but if it doesn't get some proper penetrating oil, WD40 is primarily a water displacing spray with limited penetrating properties. |
