Home > Faults & Fixes > Rear parking sensor problem on 2010 autobiography conversion |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 |
This is a common problem - have you tried taping the loom & sensors to something that resembles the bumper set up - ( broom handle ) get somebody to hold it at the correct height then retry your checks.
Sat Apr 12 2014 7:09am |
Grimps42 Member Since: 28 Oct 2013 Location: Norfolk Posts: 23 |
Thanks peachy good advice all sorted the first test I had the sensor taped but pointing down slightly that was enough to pick up the ground, re done pointing pdc higher no fine! |
Sat Apr 12 2014 8:58pm |
