![]() | Home > Maintenance & Modifications > Wheel alignment |
Should only cost you about £50-60. (including adjustment).
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Had mine at a local Indy LR garage, cost £120. Don't they need some fancy gizmo to adjust it on the RRS ?? Thats why i thought Joe Bloggs Motors can't do it - I may be wrong |
There's been talk on here of putting the car in 'tight tolerance mode' presumably via diagnostics, but I had mine done without it and the car drove as straight as an arrow, unlike the crabbing it came out of the factory with |
Topgeartowers Member Since: 18 Mar 2014 Location: London Posts: 48 ![]() ![]() |
Is it true it's best to put new tyres on to get the most accurate alignment? |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
i just had mine done after new bottom arms at a local independent tyre place, hunter wheel alignment and they said £60+vat but because it didnt need much adjustment the charged me £40 cash with a before and after printout and i watched him do it. |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
I am pretty sure that you should have a full tank of fuel when getting your wheels aligned, I can't remember where I saw it. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
LR's procedure is with full tank or equivalent weight added. 2012 SDV6 - it's missing a couple of cylinders
