Home > General > 1 year old and 1st gremlin appears
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
RRS is coming up for 1 year old and the day after I book it in for service the 1st gremlins appear
Firstly, after setting off the suspension failed to move from "access" to "normal" height, with the car telling me to slow down for height to adjust. Had to stop and reset manually but been ok since.
Secondly, the drivers seat refuses to move back to memory setting 1 after being in 2. It moves upwards and backrest reclines ok but won't move backwards although moves ok with manual adjustment.
Looks like the 1st service next week might take a little longer than I hoped!
Post #420087 Wed Apr 02 2014 11:53am
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Thats not good, hope you get it sorted.
Mine had its first service last week, no problems so far thank god. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #420092 Wed Apr 02 2014 2:03pm
JPR 1
Very annoying 1yr old Evil or Very Mad How you get it sorted pal. Any issues I am sure the wealth of knowledge on this site will be ready to help Thumbs Up Current Volvo XC90 R Design T8
Gone 2010 TDV8. Stornoway Grey
Gone VW R50, AUDI S8, ML320 Sport, FFRR V8
Stolen 2007 TDV8.
Post #420093 Wed Apr 02 2014 2:27pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Sounds silly and easily fixed. Do not worry. Vadim A.
Post #420105 Wed Apr 02 2014 5:28pm
Paulcp
Not worried since I also assume its an easy fix. The suspension glitch may be just one of those things which never appear again Rolling Eyes
Just ironic that when I booked in for the service 2 days ago I told the dealer that car had behaved impeccably and had proved faultless Laughing
Post #420107 Wed Apr 02 2014 5:41pm
Vadim
never, never say this out loud lol Vadim A.
Post #420151 Wed Apr 02 2014 11:20pm
drdelrrs
Remember a majority of cars have software that is based on a compact Microsoft core so do what you'd with your laptop I.e. reboot. For an RRS that's means disconnecting the battery for a few seconds
Post #420164 Thu Apr 03 2014 7:33am
flydive
2 suggestions.
Suspension: it could be that you pressed the up switch while the suspension was already rising automatically, so basically telling the car to raise to off-road height, hence the "complain" about speed.
Seat: Did you begin using the second key? If so, it could be that it has different memory settings '08 RRS TDV8
Post #420167 Thu Apr 03 2014 8:56am
Paulcp
Thanks for the suggestions. I always let the suspension adjust to ride height automatically but maybe the start of the glitch was that it perhaps hadn't lowered to access height sufficiently before I opened the doors etc. Used it a few times since and everything is ok so probably just one of those inexplicable happenings Rolling Eyes
Re the key, no always the same one. The seat definitely sticks when it tries to move itself backwards but strangely enough if, when its stuck, I move it back marginally using the adjuster and then press "position 1" again it moves back ok
It's not causing any hardship so will let the dealer sort it on the service Thumbs Up
Post #420171 Thu Apr 03 2014 9:45am
Paulcp
UPDATE
Prior to going in for service the electrics on the drivers seat stopped working completely with each press of any adjuster being met with a brief click.
The suspension fault never reappeared so probably just one of those glitches. On looking at the seat fault the dealer concluded that it probably needed a new motor so is booked back in in a few days time.
However, went over some rumble strips yesterday and, hey presto, everything working again! Rolling Eyes Will still let it go back in to be checked out though even though everything points to a loose connection or sticking motor.
Finally, thank you to Pete @ Land Rover for taking an interest in the matter Thumbs Up your PM was very much appreciated
Post #421761 Sun Apr 20 2014 10:01am
