Home > General > cost to replace cowl???
HandsomeWeasel
The cowl panel running along the bottom of my windscreen is slightly warped and doesn't sit tight against the bottom of the windscreen as it should.
I know the replacement part isn't too expensive (about £80), but how much should I expect to pay to have it fitted? As I don't fancy tackling the job myself.
Post #419313 Wed Mar 26 2014 6:59pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Very easy to do. Remove windscreen wiper arms, a couple of nuts. Also remove A pillar covers, a good pull.you may need to replace some clips. The bottom cowl then just pulls off. Install the same way. Otherwise visit your local auto windscreen garage.
Post #419323 Wed Mar 26 2014 8:07pm
HandsomeWeasel
I didn't expect it to be that easy! So im guessing wouldn't be too expensive to get an indy garage to do it then???
Are there any clips on the cowl that will break and need replacing?
Post #419327 Wed Mar 26 2014 8:16pm
SCdavies
From my old memory I think the clips are moulded into the panel itself. Have a look on powerful uk web site or you tube and they show you how to remove different panels. Yes a garage of sort will be able to do this job. 30 minute job.
Post #419341 Wed Mar 26 2014 10:01pm
