Home > Maintenance & Modifications > tdv8 starter motor |
range17 Member Since: 08 Oct 2012 Location: bedford Posts: 109 |
thanks very much most helpful zx12r
Fri Feb 28 2014 7:42pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Now you know why they charge so much to change it for you... 2012 SDV6 - it's missing a couple of cylinders
Sun Mar 23 2014 6:14pm |
yes agree did save £500 i suppose though zx12r
Sun Mar 23 2014 7:15pm |
Alanhenry Member Since: 15 Nov 2014 Location: Aberdeen Posts: 1 |
How did you get the starter out of the engine bay? I have just got to that bit on a starter motor changeout. |
Sat Nov 15 2014 11:06pm |
JST Member Since: 07 Dec 2014 Location: Somerset Posts: 8 |
any hints on how to change it then? |
Fri Jan 30 2015 5:58pm |
1. Disconnect battery.
Fri Jan 30 2015 9:33pm |
thank you
Sat Jan 31 2015 8:06pm |
No idea if the mount has to come out or not. I would expect that it probably does - you wouldn't write the manual telling a mechanic to spend an hour removing stuff unnecessarily.
Sat Jan 31 2015 11:13pm |
ok, my mistake, was only taking wading info off LR HUB,
Sun Feb 01 2015 10:59am |
don't worry, it takes more than an internet forum discussion to upset me 2012 SDV6 - it's missing a couple of cylinders
Sun Feb 01 2015 12:14pm |
i was intrigued by this so looked up wading depths again today.
Mon Feb 02 2015 8:39pm |
Strange that the owner's handbooks (available on Topix) should give a limit nearly 200mm less than that until 2009. I think the RRS lagged behind the D3 on this change.
Mon Feb 02 2015 11:05pm |
Oh, and I had a look at the SM change process again and it appears that the 2.7TDV6 doesn't need the RH engine mount moving. Only the TDV8 does. Presumably this is why the SM change is seen as easy (relatively) on the D3. 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 02 2015 11:08pm |
Today I jacked my TDV8 up and took off the underbody plates to check the starter replacement. As I suspected, the breather pipe has not been fitted correctly. The pipe has been routed down below the gearbox rather than up behind the engine. Indeed, in its current position, the breather pipe open end is actually closer to the ground that the starter motor is! Any proper wading is likely to see the pipe exposed to water with the result being a shortened life for the starter motor. Another example of where reliability is reduced by the lack of care/thought/effort of the dealers' mechanics.
Sun Feb 08 2015 7:47pm |
