Home > General (L494) > Performance of the SDV6 with On/Off road pack vs. SDV8
Page 2 of 3 <123>
Renaco
In relation of the full package, for me, yes.
Seen as an Engine only, the V8 Diesel is better compared to the V6 Diesel.
But both in ride compared, the construction of the new RRS is not so perfect for the SDV8. Means the balance is not as perfect as with all the other engines mounted.
But if this dose not matter, and V8 and Diesel is a must, why not.
Post #418485 Wed Mar 19 2014 8:32pm
DBA
Macedonia
That is a good point about the wight distribution for the SDV8.
So it seems the best choice is either go with SDV6 (with acceptable performance) or petrol V8 for a proper sporty drive.
There is one more option to consider though.. the hybrid, seems like it has the SDV8 performance, but should be lighter since there is only a small battery which I think should be around the middle of the car and set very low. The electric motor is a extension of the gear box... maybe the best of both worlds (SDV6/Cool? The negative thing about it would eb added complexity of course...
Post #418511 Thu Mar 20 2014 6:58am
Tboner
JLR building a Hybrid worries me to be honest , they are yet to perfect the first batch of cars and are only doing the hybrid to lower the groups carbon outputs to comply with the EU tax req's. as with all Hybrids the drive ability of the cars leaves a lot to be desired.
I think from what has been mentioned is that they may well be turning up the grunt on the SDV8 and of course there may also be the RRS GT 5.0SC appearing as well that is proven at 580HP , it is well known that the SDV8 is good for far more power but has been held back because of torque on the gear train and TEMPS , the new 8 speed handles more in other cars now and the new 9 speed handles another 15% torque over the 8 speed and of course that is now going in the cars as well.
A lot of this goes down to personal choice but IMO the car is named SPORT so should give a sporty type dynamic drive with a wide useable powerband and good for quick overtakes and should not be left for dead by other less capable cars out there with better 3.0 engines. IE the Porsche VW etc.
A close pal of mine has a SDV8 running at 18% above standard on power output and had teh same in his 2011 L322 the later covering 55K miles never missed a beat and the L405 now at 20K miles again no issues so this really proves the newer drive train handles the power with ease which is good news all round for owners as we should not be seeing gearbox issues etc as cars get older, unlike the double clutch systems. 2014 5.0SC AB
Gone 5.0 SC
Post #418513 Thu Mar 20 2014 7:24am
SVR575
As regards to the SDV6 or the SDV8 the perfomance is so close that for me the v8 is not worth the extra outlay especially as the v6 is more than quick enough for RR. Also as they are the same price i think the SC would be the better buy, unless as Tbonner says they up the SDV8s power. SVR 2018 in Santorini Black.
Post #418542 Thu Mar 20 2014 1:16pm
Tboner
but in the real world the performance is not close
Forget the BS 0-60 numbers based on a stripped bare 3.0 with no extra's fitted . that's the whole point of the thread.
Our 3.0 that my wife has is not even close to the SDv8 i have , even she has a face on with the 3.0 esp when doing an over take etc and she is not a heavy planted foot driver that is for sure.
I jump in both and the 3.0 would deff not be my choice that is for sure , and you cannot compare the 5.0SC to the 4.4 totally different drives and fuel numbers of course.
I here a rumour and only a rumour that the SDv8 is good for 398 HP and 890NM Torque without any issues on the newer 8 & 9 speed box. 2014 5.0SC AB
Gone 5.0 SC
Post #418546 Thu Mar 20 2014 2:15pm
Renaco
please, whats the 3.0 of your wife? 256HP or 292HP? dynamic pack?
thanks, ren�
Post #418595 Thu Mar 20 2014 8:57pm
Tboner
AB SDv6 2014 5.0SC AB
Gone 5.0 SC
Post #418599 Thu Mar 20 2014 9:06pm
Renaco
Thanks.
OK, let me check final the real Performance of both cars, as in my mind there must be something wrong with the SDV6 AB or your SDV8 is re-mapped? Smile
The difference you mentioned makes me woundering, but we can have a test stand and figure this out soon.
Best,
Ren�
Post #418606 Thu Mar 20 2014 9:33pm
Tboner
not remapped i can assure you , SDv6 nothing wrong with it as we have had a loan car while that has been in for issues and exactly the same , it's ok but not fantastic by any means. 2014 5.0SC AB
Gone 5.0 SC
Post #418670 Fri Mar 21 2014 9:52am
Tboner
i may try and get the car on the weighbridge when i am out in it to see what the weight is , would be interesting to see what the real numbers are ! 2014 5.0SC AB
Gone 5.0 SC
Post #418678 Fri Mar 21 2014 11:03am
DBA
Macedonia
That would be really interesting to know the real weight with all the options you have.
Post #418680 Fri Mar 21 2014 11:13am
Terryrrs
I have moved to a car that is much slower RRS Black edition but I have found that performance no longer comes into the equation be it real world or not, granted 0-60 is useless in measuring performance. My Journey times remain the same and the only difference is that I arrive relaxed. In Germany I was travelling at about 175mph and I can tell you it was exhausting just waiting for a Trabant to pull out and then coming to road works stuck in the traffic and watch the cars that I had just overtaken pass me because I had made the wrong choice of lanes. The moral is get the car you enjoy driving because performance will not necessarily get you there any quicker. The track is the only safe place if you have a need for speed. Mr. Green Mr. Green
Terry
Post #418696 Fri Mar 21 2014 1:53pm
SVR575
Well iam sure that the sdv6 is more than fast enough , if its faster than my 11mdl and thats quick enough for me. SVR 2018 in Santorini Black.
Post #418711 Fri Mar 21 2014 5:26pm
Tboner
FYI - Just taken the SDV6 AB on to the Weigh-Bridge with a half tank of fuel and weight is 2381 KG 2014 5.0SC AB
Gone 5.0 SC
Post #419123 Tue Mar 25 2014 11:17am
So it's almost the same weight as quoted by LR for the SDV8... 2012 SDV6 - it's missing a couple of cylinders
Post #419128 Tue Mar 25 2014 12:05pm
Page 2 of 3 <123>
