Home > In Car Electronics > OE DAB Module Retrofit?
Mark_TDV8
England 2007 Range Rover Sport TDV8 HSE Cairns Blue
Does anyone know if it is possible to retrofit the OE DAB module to an 07 Sport? The car has the TV and DVD player/rear screens fitted if that makes any difference.
I have read a number of threads about getting DAB into the car, most of which say to use an after market unit, but I have seen an OEM unit advertised...
The part number of the unit is: CPLA-14F720-BG
My suspicion is that this is too modern a module to fit my '07, but I thought I would ask anyway...
Mark 2007 TDV8 RR Sport HSE
2003 TD5 Discovery 2 ES
2001 TD5 Defender 110 DCPU
2003 4.4 RR Vogue [Project]
Post #417679 Fri Mar 14 2014 10:03am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Not possible to fit the LR DAB module to the 05-09 RRS as it was never an option, and only made for later cars. Aftermarket is your only option.
Although have you tried the tunein radio app? I have found that to be a good cheap alternative. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #417689 Fri Mar 14 2014 11:42am
Mark_TDV8
As suspected then, thanks for confirming.
ta
Post #417691 Fri Mar 14 2014 12:02pm
RRS Daz
I just plug my iPhone into the aux port and use my apps.
Post #417700 Fri Mar 14 2014 1:18pm
Bombhead
United Kingdom 2007 Range Rover Sport TDV6 HSE Siberian Silver
Hi, I'm getting DAB retro-fitted into our 07 RRS HSE. The company I'm going to use are :-
www.justconnectme.co.uk
Until 18th April it's about £200 for them to come to anywhere in the UK and fit it at your convienence.
Hope this helps.
Post #420963 Fri Apr 11 2014 3:12pm
