Home > Technical > Supercharger sluggish
Nickibarnes
Hi All
I am hoping someone can help, I have a 2006 4.2 supercharged RRS and have had a couple of issues with the supercharger 'kicking in' and its extremely sluggish and struggled to go above 50mph, I turned it off and revved it a couple of times next time round and the supercharger was alive again, its happen 3 times over the week.
Has anyone got any advise please?
Confused
Post #417207 Mon Mar 10 2014 4:25pm
mike_D_3781
H Nick,
No idea, but I know a very reliable mobile mechanic whose Swindon based worked on my cars for 10 years till I moved away if your interested?
Post #417209 Mon Mar 10 2014 5:23pm
a13xbb
I've just had the supercharger aux coolant pump changed on mine apparently this can be a cause of powerloss
Post #417255 Mon Mar 10 2014 10:25pm
Ridgebacks
I had a similar issue it was the wiring for the aux pump at fault 2016 SVR
Post #417265 Mon Mar 10 2014 11:04pm
jochem00
at the back of the supercharger, below the air intake there is a air return or circulation valve which I believe in your case is staying op so the supercharger is not building up any pressure.
under load this valve is supposed to close so the supercharged is going to compress air.
Post #417337 Tue Mar 11 2014 5:08pm
