![]() | Home > General > engine exhaust gases |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Hi and welcome |
Sounds like an EGR problem if there is no actual exhaust noise 2x TDV6. SE and HSE. Both returned to sender with issues👀
barz44 Member Since: 04 Mar 2014 Location: Nottinghamshire Posts: 3 ![]() ![]() ![]() |
I thought it was so thanks , now do I have change them both , or just the faulty one ? It's going in on sat to land rover |
I would do both, as a precaution..... |
It's looks like it, had them changed in2012 is it woth having them blanked off which I only do short runs in it ! |
As long as you don't intend to drive in Switzerland and Holland, blank them off, then you won't have any more issues. It's the short runs that kills them blocking everything up with carbon and soot. |
