![]() | Home > Technical > Whooshing Noise when excellerating. |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
Hi Sandra
Sandra Member Since: 18 Feb 2014 Location: Essex Posts: 18 ![]() ![]() ![]() |
It sounds like it's coming from the top right hand corner of the dash. We had the blowers switched off also so we could hear properly. I think it's like an air type whooshing but hard to tell, it's not the fan because it was all switched off. But it like it whether the car is cold or running a while. |
are you getting any smoke out the back at the same time as revving ?
No smoke at all.
best bet is open the bonnet and get someone to rev the engine the inter cooler pipe is at the front drivers side top of the radiator you may be able to pin point the whooshing sound better
Ok thanks I will try that, and let you know. |
You don't say which engine is in your car, is it down on performance ? If its a v6 then it could be a split balance pipe which runs behind the engine .. 2008 G4 RRSport TDV8 current
J.blase Member Since: 01 Jan 2014 Location: Essex Posts: 24 ![]() ![]() ![]() |
Hi sorry it's a tdv8 thanks. |
In that case it could be warped manifolds. Something that is a known problem on the V8 engine.. 2008 G4 RRSport TDV8 current
