Home > In Car Electronics > Blackvue with lazy GPS.
drdelrrs
I Had my Blackvue replaced with a failed GPS unit.
Despite Pittasoft saying it has a " ...built-in high sensitivity..." GPS the new replacement takes upwards of 17minutes before getting a GPS signal lock on the first trip of the day.
Today on a visit to the pub, a run of 35 minutes in open countryside, it failed to get a GPS fix at all. I don't really want to wire it through a 'power save' so its permanently live.
Apart from wanting the Blackvue to perform as advertised: the car can be driven by other drivers so the speed and location trace is important to us.
Anyone have the same problem?
Anyone have a better performing make of camera?
Post #415866 Thu Feb 27 2014 8:28pm
muddywheels
Milk Float Man
Mine too drdelrrs Thud
After reading your post I noticed my GPS light has not been on for a while so Just checked files and no map or gps data on any of them Evil or Very Mad
Will try restoring factory settings to see if this fixes it then contact HIDS4U Big Cry Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #416014 Sat Mar 01 2014 9:43am
drdelrrs
My supplier offered to replace this second unit on the basis of "3rd time lucky".
However I've decided to try a different make which is due Monday - I will report back on its ability to pick up a GPS fix quickly.
I have a Road Angel De-Lux unit that gets a GPS fix within seconds which suggests its not the heated screen that's blocking reception.
Post #416020 Sat Mar 01 2014 10:03am
Terryrrs
I find the front screen can block sat signals. I tired my garmin and it took ages to get a signal.
Terry
Post #416021 Sat Mar 01 2014 10:05am
drdelrrs
The heated screen's elements will attenuate the signal to some extent so its a matter of finding a product with good sensitivity.
Unfortunately there doesn't seem to be an in-car camera system on the market that has a remote aerial option.
I'm wondering if its possible to get into and 'fit' a connection for an external aerial - sure it'll destroy the warranty but it might be worth it (or I get bored enough to play).
Post #416025 Sat Mar 01 2014 10:29am
muddywheels
Milk Float Man
I think I have fixed mine Confused
1. Removed SD card and formatted it
2. Downloaded latest FW - http://www.blackvue.com/en/contents/sub3.a...hstr=dr500
3. Installed FW on SD card
4. Replaced SD card in BV and restarted
5. Removed SD card and formatted again
6. Replaced SD card and restarted BV - GPS light cam on again for first time in ages
7. Removed SD card and adjusted settings to my requirements - miles, intervals, etc
8. Replaced SD card and all working ok at the moment
Was a load of Censored having to run in and out of house - why you can't use a smart phone is beyond me Evil or Very Mad
Bonus is the voice message about wrong version every time switched on since last update has now gone Very Happy Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #416030 Sat Mar 01 2014 11:06am
drdelrrs
^^^^ That's a result.
My supplier has mentioned how sensitive the Blackvue is to the quality of SD card (must be HD) and the method of formatting.
I'm in a mind to 'break' into the camera and see if I can execute a mod. similar to Flack's "Cheap GPS" post where he describes how he found a £6.49 solution to a failing GPS aerial in the shark-fin. The 'external aerial could then be position in the corner of the screen away from the heated wires.
The worst that can happy is that I screw £200+ worth of camera Big Cry
Post #416064 Sat Mar 01 2014 5:52pm
muddywheels
Milk Float Man
Mine is picking up gps instantly now so don't think heated screen is problem - software issue imho Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #416074 Sat Mar 01 2014 6:38pm
drdelrrs
^^^ Yes mine was the same - the issue was always on the first trip of the day when it could take more than 20minutes. Once it had got a fix then, if the next trip was within an hour or two, it would achieve a fix within minutes.
So you could be right - I asked makers Pittasoft if it could be the relationship between the internal capacitor used as a battery and their BIOS commands; they simply referred me back to the retailer.
The camera I have decided to buy as a replacement has 20 minute battery which allows you to take the camera out of the car and record the scene of an accident or other event.
Post #416084 Sat Mar 01 2014 7:02pm
muddywheels
Milk Float Man
Ignore me - just been out and losing gps signal on and off all way home so looks like it's going to have to be repaired or replaced Evil or Very Mad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #416088 Sat Mar 01 2014 7:37pm
