Home > Maintenance & Modifications > tdv8 starter motor |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
IIRC, it's a of a job |
Wed Feb 26 2014 10:07pm |
range17 Member Since: 08 Oct 2012 Location: bedford Posts: 109 |
Think it is messing me about ,clicks a few times then works ,want to check connections on it ,not sure where to
Wed Feb 26 2014 10:21pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Mine did that for a while. Then it died. 2012 SDV6 - it's missing a couple of cylinders
Wed Feb 26 2014 11:47pm |
Did you replace it yourself ? zx12r
Thu Feb 27 2014 6:38am |
No, I had it done by the dealer under warranty. 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 27 2014 10:02am |
ok thanks zx12r
Thu Feb 27 2014 10:08am |
Mark_TDV8 Member Since: 17 Nov 2013 Location: West Sussex Posts: 42 |
Was the starter itself clicking, or did you get no response when turning the key?
Thu Feb 27 2014 11:15am |
Yes starter was clicking ,when I try for second /third time it starts fine ,I am thinking its the solenoid sticking,
Thu Feb 27 2014 11:54am |
Sorry, not done it - trying to diagnose a fault on my own truck. mine doesn't click, it just doesn't do anything when you turn the key sometimes. I suspect mine is just a loose or wet connection on the starter solenoid...
Thu Feb 27 2014 12:01pm |
Sorry to hear that for you ,I am looking at mine this lunch time and hopefully changing it soon ,if so I will
Thu Feb 27 2014 12:03pm |
Cheers - will be interested to hear how you get on. Good luck... 2007 TDV8 RR Sport HSE
Thu Feb 27 2014 12:05pm |
Looking at the workshop manual, the job does look, as Mikey suggested, to be a 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 27 2014 11:04pm |
Yes i agree had the skid plate off yesterday and was able to see the motor ...just !!
Fri Feb 28 2014 6:51am |
You have a PM 2012 SDV6 - it's missing a couple of cylinders
Fri Feb 28 2014 6:06pm |
