Home > Technical > ISSUE When start car grinds, HTC FAULT
XweaselX
United Kingdom 2007 Range Rover Sport 3.0 TDV6 Autobiography Siberian Silver
HI guys
Nice forum here
I got a Range sport 3.6TD range rover sport AUTOBOILGPHY
It has been sitting a couple weeks then today
when pulling off
The car come make grinding noise liken the brakes was staying on,
after that there some some words come up on the dash
HTC fault
the suspension lowered
the DCS light come on
Brake pad light come on.
I did some more tests
when i turned car off then turned back said no faults until i started to drive again then the grind noise happened and same faults appeared.
more test when i started the car i pressed the DSC button then moved i would not grind but after 30 seconds oif traveling the HTC fault and suspension would lower again.
More tested start and traveled didnt grind this time but i had foot full down on pedal and car didnt wanna move didnt rev or anything until the HTC fault light popped up.
Need some help on this please guys
Thanks Anthony
Post #414405 Mon Feb 17 2014 2:01pm
at a guess the EPB is stuck on and that could be the grinding noise
and a flat battery can cause the dash to light up
Post #414406 Mon Feb 17 2014 2:10pm
XweaselX
Car started fine. The frinding noise and goes feels fine after all the warning lighst have come on
could it be somthing to do with the ABS?
Post #414409 Mon Feb 17 2014 2:39pm
fault codes might have been stored, pop in to a dealer or LR Specialist to have them read Idea
Post #414410 Mon Feb 17 2014 2:55pm
