![]() | Home > General (L494) > Max Speed on a RRS SC |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
I would imagine that it's been electronically limited to 135 MPH.
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Assuming you have the new RRS 5 litre SC engine, its top speed is specified in the book as 155mph which is 250kph.
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 ![]() ![]() |
Yes there is a variable speed limiter as Mark says.
hornbaek Member Since: 11 Dec 2013 Location: Richmond Posts: 39 ![]() ![]() ![]() |
I will have to speak to the dealer about this. There is a very penetrable highly pitched (loud) noise when you go above 135 mph which abates gradually when you slow down below 135 mph. After having tested it a couple of times I don't think it has anything to do with speed limiter our other electronic issues, rather something to do with the airflow around the car. |
Quite difficult for you or them to reproduce the problem on the A3... are you sure it's not one of your passengers getting nervous...
I agree with the procedure but as I was alone on my way back yesterday I did not want to fiddle with my I-Phone at that sort of speed. I think you can only reproduce it at Millbrook on the Oval so will see how LR proposes to check this.
That's good to hear that the RRS inspires confidence at speed, not bad for what is quite a tall vehicle with a large cross-sectional area.
Possible causes, wind noise from window wipers, a panel gap on the front of the car, or wind sweeping under the car causing something to vibrate at such speeds. Ive experienced all these issues before on other vehicles but not the RRS. What size wheels are you running? |
I agree. The dealership will not have a clue unfortunately.
Occasionally you can get very high pitched whine from timing belts or air-con, alternator / other ribbed belts that are only heard in the cabin at very hi-speed is there any indication when you rev the engine while stationary - gently build the revs.
Yes, I'm wondering whether the supercharger drive belt (I assume it is belt, not chain, driven) is slipping on the pulleys at this high engine speed and loading? Mark
I took it to Guy Salmon this afternoon. They were clueless and further told me that there was no way that they could test this at warp speeds. I will now call a dealer in Germany and see whether they have had same problem.
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
I can confirm it does 155mph |
