Home > Maintenance & Modifications > I just found a new secret menu
Page 6 of 8 <12345678>
Speedinnovation
United States 2006 Range Rover Sport Supercharged Java Black
Thats what I meant by dangerous see changing certain f blocks will maek the system hang and if you turn on certain ones you can lock the system for while that why I didnt want to give the code out. also you can go to the most menu and reset it and you will see whats disabled also if you exit back to the normal nav screen then certain options will appear or disappear 2006 Range Rover Sport Supercharged Speedinnovation Custom upgraded supercharger pulley,exhaust, tv mod,smoked lights, smoked side markers, 23" rinspeed wheels, 315 tires all the way around, arden kit
2003 996 Porsche Full gt3 specs custom cams,carpc,techart springs,techart shifter,4 point rollcage,19" work vsxx 315 tire on rear, custom engine software
2003 BMW 330 CI, h7R springs,18" sport wheels,clear markers, custom engine software
Arriving in 6 weeks is my new baby
2007 CLS63 AMG
Post #41371 Sun Jun 25 2006 7:14am
RAD
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
So not wishing to be rude......it appears that you don't have a clue?
Post #41378 Sun Jun 25 2006 10:16am
Peter
United Kingdom 2006 Range Rover Sport SDV6 Autobiography Java Black
Now that's harsh! Laughing It's finally gone! Replaced with BMW 730SE in Sophisto grey Xirallic finish with Oyster (Ivory) and black interior. DAB, Climate glass, Ceramic iDrive and gear selector, power boot and iPhone Bluetooth pack - luvvin' it!
I miss my old RRS "bucket" rattling around but it just had to go!
Post #41379 Sun Jun 25 2006 10:22am
Yeah but true Shocked RRS TDV6 Gone but still around
Post #41381 Sun Jun 25 2006 10:26am
PaulB
Speed,
You still haven't answered my question regarding your supercharger pulley upgrade Question
Paul
Post #41384 Sun Jun 25 2006 1:22pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
Can anyone explain how do I type it in? 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #41394 Sun Jun 25 2006 5:09pm
Speedinnovation
Smarta$$ if you dont have any resourcefull comments to say or you dont have any findings to report then just shutup. If you want to learn about hacking the system then wait just like everyone else its not as simple as 123... Sorry mate if you cant follow along or if its to difficult for your mind to comprehend you should go to this forum link below I am sure it wont hurt your head too hard. Wink
http://forum.muppetcentral.com/showthread....ough+eddie
This menu was just found and it has other capabilities that are still unknown.I have documented some of the fblock findings I was able to do and replicate something on a another rover aswell as mine. Goodluck everyone on documenting the findings.
BTW I was out in the truck last night and there is another code that I found basically it displays a file list of software bits that are installed into the system. Now I have to find away to get them out and modify. 2006 Range Rover Sport Supercharged Speedinnovation Custom upgraded supercharger pulley,exhaust, tv mod,smoked lights, smoked side markers, 23" rinspeed wheels, 315 tires all the way around, arden kit
2007 CLS63 AMG
Post #41411 Sun Jun 25 2006 6:58pm
PaulB
I want to know about your supercharger pulley upgrade Confused
Paul
Post #41412 Sun Jun 25 2006 7:07pm
Speedinnovation
just pm me since this thread is about the nav system I will answer questions that way 2006 Range Rover Sport Supercharged Speedinnovation Custom upgraded supercharger pulley,exhaust, tv mod,smoked lights, smoked side markers, 23" rinspeed wheels, 315 tires all the way around, arden kit
2007 CLS63 AMG
Post #41413 Sun Jun 25 2006 7:18pm
tf9
Speedinnovation
Would you be so kind to tell how activate this code? 2014 Mercedes-Benz S500
2013 BMW 530d
Post #41416 Sun Jun 25 2006 7:40pm
PaulB
I presume you enter the code using the hidden button.
From the navigation screen, select the button in the bottom left corner. In the next screen pres and hold for around 5 seconds about halfway across the screen right at the top (there isn't a button). This should bring up a numeric keypad for you to enter the access code.
I hope that helps.
Paul
Post #41432 Sun Jun 25 2006 9:55pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
PaulB, that accesses the navigation diagnostics, not the main diagnostics menu. The code Speed found appears far more "intriguing" in the main system diagnostics. As a nav diag code, its usefulness appears very similar to the "known" 753 code, with the addition of a S/W download button (and no need to recycle the ignition to exit the diagnostics menu, as there is now a "Return" icon in the upper left corner of the screen that brings you back to the nav main menu.)
To access the main system diagnostics using Speed's code, the procedure is a tad different. First, with the monitor turned on go to the infotainment's Main Menu by pressing the right HARD button under the monitor. Second, press the upper center portion of the touchscreen (about an inch to the right of the letter "U" in the Main Menu header) for about 7 seconds (nothing visual will happen at this point), then release the touchscreen. Third, press the left HARD button under the monitor. After a couple of seconds, a Diag PIN entry window will be superimposed over the main menu - looking a bit different than the nav diag PIN entry screen. Using the touchscreen, enter the code followed by OK. You should then see the diagnostics menu. Proceed at your own risk from there.
Post #41479 Sun Jun 25 2006 11:05pm
I didn't want satnav anyway Big Cry
Post #41539 Mon Jun 26 2006 12:30am
tasmod
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
Haven't had time to follow this thread much but maybe this will help someone.
Post #46692 Tue Jul 25 2006 9:48am
tasmod
That was just one bit from the 236 page pdf of the MOST specification.
If someone can make use of this, I can email them a copy. It's 1.8meg in size.
Post #46693 Tue Jul 25 2006 9:51am
