![]() | Home > Maintenance & Modifications > SDV6 ece re-map |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Just be aware that the only way to remap the SDV6 is by removing the ECU. 2014 L405 SDV8 RR Autobiography |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
Opening up the ECU will void your warranty.
You could buy another ecu like some of the guys over on the gippo site, get that remapped then just swap the ecu back over when vehicle is due in for service. |
MarkOne Member Since: 22 Dec 2012 Location: NI Posts: 8 ![]() |
Funny I heard that same story ![]() Firstly how was it noticed that it had been remapped? And from what I believe the new VW stuff can be remapped from obd. |
ikeysolomon Member Since: 02 Jul 2007 Location: High Wycombe Posts: 60 ![]() ![]() ![]() |
Overfinch do a map for the SDV6. If you went that route, would you still be in warranty??
