Home > Maintenance & Modifications > 3.0 tdv6 engine conversion from a 2.7 tdv6 CAN IT BE DONE?
jonesy_boys
United Kingdom 2006 Range Rover Sport TDV6 HSE Firenze Red
Hi guys, have anyone fitted a 3.0 TDV6 into a 2.7 TDV6? My current engine is knackered and just wondered if it can be done? (dont have to change many parts)? if anyone has can you let me know how you done it and what has to be changed. many thanks.
Post #413072 Sat Feb 08 2014 10:35am
flack
Nothing is impossible if your pockets are deep enough, but it would be a major job as the wiring loom is completely different, the main ecu is different, the turbo's are different I would think unless you have access to some top end diagnostic to change it all then I don't think it would be worth the effort..
Unless someone comes along that's done it to point the way..
Flack Thumbs Up
Post #413133 Sat Feb 08 2014 8:55pm
Disco_Mikey
Mr Flack. Do you know if the ancillaries from the 2.7, will physically bolt onto the 3.0 block?
Post #413159 Sun Feb 09 2014 8:40am
flack
Not sure Mickey but I would think there would be differences, as you know some parts are quite a different shape on each model..Most of the coolant pipes are different and I think the egr valves are also not the same.
Flack Thumbs Up
Post #413177 Sun Feb 09 2014 11:03am
