Home > Technical > rrs centre propshaft bush
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
when refitting my gearbox today i noticed that the centre prop bush is perished and split,land rover want £480 plus vat for a prop ,,anyone know if the bush/mount can be bought Idea silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #413003 Fri Feb 07 2014 6:18pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Yes you can there about 40£
Pain to split the shaft
I did one but then found the UJ one end was very stiff
So paid 320 for a new oe shaft
No one had one in stock most are around 250£
On the net
Post #413019 Fri Feb 07 2014 8:58pm
gazzc
Cheers mate. What kind of symptoms do you get if left. Is it vibration under load silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413022 Fri Feb 07 2014 9:05pm
theforman
United Kingdom 2005 Range Rover Sport TDV6 HSE Adriatic Blue
Hi mate
i changed mine a while back pretty sraight forward, got mine off ebay,,
eBay item number:321076755063
hope that helps
Fogot to mention, check for compatability of the year of your rrs be for you buy
Post #413023 Fri Feb 07 2014 9:22pm
gazzc
Cheers pal. Will do silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413025 Fri Feb 07 2014 9:31pm
gazzc
I'm quite clued up but can you give me a quick run down of how to fit it. Prop shaft on bench cheers Bow down silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413026 Fri Feb 07 2014 9:53pm
jochem00
how many miles did you do with that propshaft?
I get a slight vibration under constant load but it dissappear when I accelarate or decelarate so I suspect to have the same issue. mine has 60.000 miles.
Post #413314 Mon Feb 10 2014 3:27pm
gazzc
My red sport is on 120k but my silver one is on 115 and ok so I would imagine its the way they are driven silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413340 Mon Feb 10 2014 4:56pm
