![]() | Home > General > range rover engine |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
they havnt kinked a fuel line when refitting engine have they,i take it you have fitted new fuel filter,when it is running does it rev up properly silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
What engine are we talking about? V6, V8. Petrol or diesel? 2x TDV6. SE and HSE. Both returned to sender with issues👀
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
The OP has a 2008 2.7 TDV6. 2014 L405 SDV8 RR Autobiography |
Sounds like a coding issue.......and a job done by those that don't know what they were doing |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
If it was coding, I would expect the car not to start at all.
Your presuming that everything was fitted as removed from old engine.
I will assume you are refering to a TD5 Disco. These do need the injectors coded, and programmed into the ECU.
I assume that you have fitted a Euro 4 Engine, not a Euro 3. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Basic engines between EU3 + EU4 are the same, but most parts bolted onto it are different.
hi did you get it running if so what was it as i cant get mine to run |
