![]() | Home > Faults & Fixes > parking sensors fault |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Have you checked the front ones? 2014 L405 SDV8 RR Autobiography |
medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148 ![]() ![]() ![]() |
Yes and got nothing :-/ |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Any error messages |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
With car running and park brake on select a gear preferably with some one sitting in with foot on brake put your ear on each sensor and listen for a clicking noise the one that doesn't click is faulty and will throw all of them off. But first check the wires going to them as they break/split |
Thanks will try that next, only tried it with the engine off |
. No error messages ![]() |
no noise from the PDC :-/ DONT NO WHAT IT CAN BE |
Gary7734 Member Since: 22 Nov 2013 Location: Banbury Posts: 19 ![]() ![]() ![]() |
Have had similar problems myself and garage eventually found one of the sensors had leaked water in, thankfully under warranty as each sensor had to be disconnected and then the system tested until they found the faulty one. |
Think I'm going to take it to a 4x4 specialist to get this sorted once and for all |
Medders - I think since you've just had the cam-belt and other things done it might be worth checking the under-bonnet connections and fuses. |
I spoke to the 4x4 guy and he said if there nothing on the dash then could be a fuse ..... Anyone no what number fuse and where as again I'm new to the range rover |
