Home > Technical > Squealing noise from rear right hand wheel when reversing.
Purplestarr911
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Hi from a recent new member. I'm seeking advice about my very recently acquired 2007 RRS which has a strange squeal from the rear right hand side wheel when accelerating in reverse. The sound is similar to that of a slipping fan belt and only occurs when slightly accelerating in reverse gear. The rear brake discs and pads have just been replaced by a non-LR garage, but the noise is still evident. I am worried that there may be something on the way out so any advice gratefully received, please. Thanks in advance.
Post #412263 Mon Feb 03 2014 6:18pm
Disco_Mikey
More than likely, this will be due to the EPB shoes rubbing against the backplate. Fairly common issue.
The backplate should always be greased to stop the shoes squealing when replacing discs and pads Thumbs Up
Post #412288 Mon Feb 03 2014 7:38pm
Purplestarr911
Many, many thanks, Disco Mikey. I will try to get this sorted a.s.a.p. as the noise is attracting too much attention when reversing out of parking spaces!
Post #412378 Tue Feb 04 2014 8:54am
