Home > Technical > Problem with 2009 RRS TDV8 |
I'd be checking for mucky fuel and fuel filter, then it that's OK fuel pump pressure, if still OK then return fuel line. |
Mon Feb 03 2014 2:37pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
check if the intake piping is still OK and not cracked.
Mon Feb 03 2014 4:46pm |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
Fuel pressure issues I would of thought would raise an error code?
Mon Feb 03 2014 6:16pm |
^^^ Paul, you could be right but, I was wondering whether it may only show up under high flow conditions rather than at the time the technician has his box of trick connected. |
Mon Feb 03 2014 8:24pm |
