![]() | Home > General > Weird suspension behaviour |
If you have touch screen put it into 4x4 mode and check you have four sensors showing. Sounds like a ride height sensor issue and ecu is saying stay in higher mode til it can see all four wheels. 2x TDV6. SE and HSE. Both returned to sender with issues👀
norman1979 Member Since: 24 Apr 2013 Location: London Posts: 21 ![]() |
Yes the four sensors are showing. Little red squares just above the tyres I presume? |
Worth driving around and keeping an eye on screen if squares go green. Also if you have recently had battery changed, possible that you need system checked by fault mate to ensure that it knows where it should be. 2x TDV6. SE and HSE. Both returned to sender with issues👀
theforman Member Since: 02 Mar 2012 Location: wolvo Posts: 16 ![]() ![]() ![]() |
hi mate
