![]() | Home > Technical > Daytime running lights |
Mattmsm Member Since: 19 Jan 2014 Location: Notts Posts: 4 ![]() ![]() ![]() |
Hi they should be able to configure DRLs with diagnostics
G4LAND Member Since: 16 Jan 2007 Location: VIGO Posts: 154 ![]() ![]() |
JimR Member Since: 20 Dec 2013 Location: Lichfield Posts: 66 ![]() ![]() ![]() |
I asked the dealer to acctivate mine when it went to have it's number plate fittted because I had read the same thing in the manual.
I tried to enable on someones (why you would want it is beyond me) but basically you couldn't.
I saw a new Disco with the DRLs on today, they are very bright, i can't understand why they make a law for all new vehicles to have them fitted when the manufactures provide a switch to turn them off |
It can be done I have done a few but you only get the headlamps to work, if you want drl's like the new ones you need to get them fitted, a few members on here have had them done...
True, I naturally thought he meant the fairy lights. The headlight on is easy through the ccf.
On the subject of fairy lights on the RRS, is it possible to get brighter bulbs for these as they arn't much use otherwise? Anybody have any ideas what size bulb is required? |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
What do you mean by fairy lights?
Fairy lights, the little bulbs lit up in the headlights.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Had mine about 9 months |
Michael calvert Member Since: 09 Feb 2014 Location: near leeds Posts: 219 ![]() ![]() ![]() |
ive been looking to get my FAIRY lights turned on!! think they look the part TBH
tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308 ![]() ![]() ![]() |
Like the thought of having DRL's and the Fairy lights turned on....
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
you can turn on your drl's using the IIDtool ,
