![]() | Home > General > Weird suspension |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
The experts here will want to know the fault codes |
jetbags Member Since: 29 May 2011 Location: Margate Posts: 144 ![]() ![]() ![]() |
I have not had the car looked at yet, so cannot advise on the fault code showing..... Just thought it really weird that it would throw the fault up yet there is actually nothing wrong if you turn off/on again...
what light is being displayed and what colour is it ? |
It's the usual yellow light with an icon of a car with arrows pointing across the roof as if indicating side to side movement. 2005 Rang Rover Supercharged
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
Have you checked the dynamic response reservoir? You might have a leak somewhere and this is indicating low fluid levels. 2012 SDV6 - it's missing a couple of cylinders
when it displays red/orange is when you need to worry ! |
I have no idea what that is,where it is or what it does !!!! so i guess the easy answer is no i have not checked that..... low fluid levels ??? i thought the suspension was only operated via air bags on the suspension arms... or am i totally being a muppett here ? 2005 Rang Rover Supercharged Loving every minute ! |
I think that the Supercharged version has always had a dynamic anti-roll bar system (later standard on versions such as the TDV8). This uses power steering fluid in adjustable anti roll bars to allow the vehicle to resist roll on tarmac but still have good articulation off road. The reservoir is at the front of the engine bay on the driver's side (RHD) and has a yellow cap.
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
I had a similar issue with my previous car. The dealer (and I guess an independent) can do a leak test on the suspension system to help identify it. My dealer had to do this twice |
Excellent advice, Thanks so much.... I'm off to see what i can find. Thanks again. J. 2005 Rang Rover Supercharged Loving every minute ! |
I think i may be at the same point with my Range Rover, I am going to put it into the garage next week and see what they pull up, think it may be time to say goodbye to the Land Rover brand and go back to something Reliable....... J. 2005 Rang Rover Supercharged Loving every minute ! |
rosssavage Member Since: 08 Feb 2013 Location: London Posts: 1 ![]() |
I have the same thing on mine. Had it serviced the other day and Land Rover said it needs a new compressor for £750. But because I had it serviced 13 months after the last service the warranty company say my cover is void. I've sent lots of angry letters, see where that gets me.
Ok,
Any chance it could be moisture (either in connectors or suspension air system) freezing at low temperature. Was it particularly cold on the day you had the Christmas tree display? |
