Home > Technical > front end dropping to access height when parked |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
If its dropping then you have an air leak on the front either at the valve block air pipe or a air bag on one of the front legs..
Wed Nov 13 2013 8:55pm |
LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75 |
thanks, wouldnt an air leak throw up a warning ? and would there be an air leak on both sides ?
Wed Nov 13 2013 10:09pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
The system wakes up and levels itself every 6 hours so a leaking bag might cause the vehicle to "chase" the front end down in order to stay level. I would have thought, however, that a leaking bag would cause the compressor to work overtime whilst driving and this would then throw up an over-temp error code.
Thu Nov 14 2013 12:42am |
thanks,
Thu Nov 14 2013 9:49am |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
Locust, can we have an update on your findings please, as mine is very similar. |
Sun Jan 26 2014 11:39pm |
Hi, i had my valve block out the weekend, and it was very gunked up, ive cleaned it, its better but still drops so will get a new one,
Mon Jan 27 2014 2:57pm |
Mon Jan 27 2014 2:59pm |
thanks for the update mate
Mon Jan 27 2014 5:51pm |
Speak to dan at duck worth parts on here. 78 quid plus vat I've not got it yet.
Mon Jan 27 2014 7:04pm |
Paul will have that radiator too in the TDV8... 2012 SDV6 - it's missing a couple of cylinders
Mon Jan 27 2014 7:06pm |
There's a fella who stripped one down on here, done a good write up too , but i dont remember him mentioning rad, so you may be ok
Mon Jan 27 2014 7:10pm |
I followed that strip down guide but I don't know if mine is beyond service. As from the pic it seems to be leaking condensation form the join.
Mon Jan 27 2014 8:09pm |
It's not ecacly a lot of money so i would just go with that to start, as i am. |
Mon Jan 27 2014 8:33pm |
Lol I get you. But I'm not gonna start chasing my tail replacing parts and hoping.
Mon Jan 27 2014 8:46pm |
