Home > General (L494) > Remap yet
Apart from it voiding your warranty. Whistle
Post #410891 Fri Jan 24 2014 7:26am
^^^^ Yup Thumbs Up ......given that from what's posted on here a lot of the time LR try to wriggle out of just about every claim that's made their way, even when the fault lies clearly at their doorstep, I sure as hell wouldn't be playing around with £60-80k's worth of motor.
Performance cars, I would have a slightly different attitude to, but at the end of the day, if you're buying an RRS2 and wanting speed, either spend the pennies and get the S/C or leave it alone IMHO. ON THE WAY: BMW F21 M140i
Post #410893 Fri Jan 24 2014 7:45am
mcma1
2007 Range Rover Sport TDV6 HSE Java Black
land rover dealer re programmed my last sport, still have the invoice, £700 plus vat. They say they will offer the same for the new sport if I want to. So you can maintain warranty. 2011 Defender X-tech
Post #410894 Fri Jan 24 2014 8:05am
paulL
Spain 2013 Range Rover Sport SDV6 Autobiography Fuji White
Just to confirm... The question was asked regarding MY13 AND 14 with the answer for both being flash via OBD port, not ECU removal... Its the same engine... 2013 RRS SDV6 Autobiography Fuji White
2007 RRS TDV8 HSE - gone -
2005 RRS TDV6 HSE - gone -
Post #410899 Fri Jan 24 2014 8:22am
big pimp
You sure about that PaulL?
Dms don't seem to think so? MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #410997 Fri Jan 24 2014 6:52pm
paulL
That's exactly what the (obviously clueless) idiot said on the phone to me yesterday and I specifically asked regarding the 2 MYs... 2013 RRS SDV6 Autobiography Fuji White
Post #410999 Fri Jan 24 2014 7:16pm
Disco
JE Engineering.
JE are now showing Remaps for both the V6 and V8 diesels.
Post #420103 Wed Apr 02 2014 4:52pm
Tboner
JE , they cannot make there minds up what the power is on the SDV8 or supply a printed curve of the power run , so i would be careful on that one.
If you have to split the ECU you brake the seal that is on them, so unless you have a tuner who has the factory seals ( stickers ) it will be easy to spot. Also make sure who you go with will redo the tune if the factory updates that get carried out during service wipe the new map.
And finally even Porsche can now spot a map on the 997 & 991 Turbo cars just via there plug in diags ! 2014 5.0SC AB
Gone 5.0 SC
Post #420181 Thu Apr 03 2014 10:37am
