![]() | Home > Faults & Fixes > Help with fault codes |
A quick google throws up:
I'm sure someone with more technical nouse will be along shortly ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
dannydee Member Since: 02 Apr 2013 Location: birmingham Posts: 7 ![]() ![]() |
Many thanks for the reply.
Anyone with more techny knowledge able to help this chap out??? |
jsamps Member Since: 11 Mar 2014 Location: Nottingham Posts: 12 ![]() ![]() ![]() |
I have a RRS 06 tdv6 and im getting an esf message thats indicating absolute pressure failure (I think the codes p0106) problem is the car is fine and is driving the same as before the message came up! Ive had the map sensor checked,egr valves are fine and also had the turbo looked at cleaned and all seems fine? Anyone else had this before? Even the main stealer cant find out what the cause is! There only solution was to replace the turbo!!! Shocked
danRR Member Since: 17 Aug 2013 Location: London Posts: 3 ![]() ![]() |
what year and model is this i can look up the fault more specifically for you.. could be a battery/charging or an earth issue.. "check brake pads " can only really be brought up by a pad sensor wire worn or circuit fault... radio is usually the first thing u notice when battery voltage goes low, aswell as multiple non comms fault codes like u have there... LAND ROVER TECHNICIAN |
