![]() | Home > Tips & Tricks > If you have squealing rear brakes read this |
Why didn't you allow them to fix it RR?
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
I left it because it only squeals every now and then and not every time I release the EPB. If it WAS every time I would have it done for sure.
Cheers, agree with you about if it is happening regularly to get it looked at. The only time I have ever suffered it has been when the car has been offroad and usually an underneath washing session with the garden hose seems to cure it. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Ours does it intermittently but as it now has 7,500mls on the clock ( |
Mine does that too every now and again, but given I'm past my first service and now on nearly 18k miles I might have missed the boat a little bit! |
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 ![]() ![]() |
Not in the case of the RRS & D3 Tim, the EPB operates a set of shoes against a drum at the rear inside the disks on both sides ![]() ![]() ![]() ![]() |
Cheers for that Slimer, something new learned for today! |
True, service dept told me that too, they mentioned "drums" and I harked back to my Series 3...I said...Doesn't it have discs? Anyway, you now know the answer. L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Why is that (10K miles or first service whichever comes first)? If it is a defective EPB causing the squeal, or any other cause other than worn pads or rotors, shouldn't the full warranty on the car cover it? There's even a TB on the EPB issue. ![]() |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
That's exactly what I was thinking too |
Dealers = Stealers. FACT! Runner up - 2009 Best Avatar Award |
Donkey Dan Member Since: 13 Dec 2006 Location: North East Posts: 4 ![]() ![]() |
New here fellas! There are modified rear handbrake shoes available for RRS and dealers will change them regardless if you have a good dealer. |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 ![]() ![]() ![]() |
Thanks for info Donkey worth noting MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Would these "shoes" be the same for every model ?? ![]() " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
